dtarin started following Representation of gaps along tracker when using PVcase scenes and Electrical Mismatch Losses
Electrical shading loss has been around for a long time. It is likely the 7.2 report was run on linear shading, or the site was modeled perfectly flat with backtracking enabled and no shading objects present to cause electrical shading loss.
You can change the settings for both types of messages. The shade scene module count has no impact on simulation results. - Yesterday
LauraH started following Representation of gaps along tracker when using PVcase scenes
Hi, Whenever I read in a PVC file for a shading scene, the array area and number of modules shown by PVsyst don't match the array design. After some thought, it seems that the array size is being inflated by the size of various gaps along the tracker: gaps between modules, motor gaps, and potentially joint gaps. Is there any way to correct this? It causes error messages. Optimally, PVsyst would get this information from the PVC file.
DUARTE Jean-Marc joined the community
N.Y. joined the community
kasemsin joined the community
Robert Boateng joined the community
additiondare joined the community
ruthik joined the community
KevinsNuast joined the community
Enzo Melgar joined the community
