Good afternoon world -- I've recently imported an inverter .ond file. Within the main parameter tab of the grid inverter definition, I'm receiving an error stating
The reference voltage should be within the VmppMin...VmppMax range.
I've tried a few different ideas, but the error hasn't removed.
If there's an existing topic, please redirect me there.
This means that you have defined efficiency curves for 3 different input voltages (see the "Efficiency curves" page).
But these input voltages are not well defined (they should lie between the Minimum and Maximum MPPT voltages, i.e betqween 888 and 1275 V in your case).
  • 1 year later...
  • 5 months later...
