Hi all,
I am trying to run a simulation of a 100kW system.
The system contains 1 central inverter with 1 MPPT.
However the panels have 3 orientations that are slightly different to each other.
I understand with 2 orientations, i can use the mixed #1 and #2 option, however what if there were 3 orientations connected to one tracker, is there a way to run an successful simulation?
Please let me know.
Thank you.
PVsyst only treats the mix of 2 orientations on a given MPPT input.
If you have 3 orientations, you should define an average between two of them. The results will not be very different.
  • 3 years later...
When do you mean with average between them? Lets consider an extreme case where we have 2 orientations: -90S and +90S. The average would be 0S (??) but the result couldn´t be more misleading.
I am trying to compare mismatch losses of central inverters and string inverters for minor differences in orientation.
Thanks in advance.
  • 2 weeks later...
The simpler way is to redefine your inverter with 3 MPPT inputs, and attribute one sub-array to each input.
The mismatch between orientations (i.e. between strings in different orientations) is usually very low (a fraction of %). You can check this by defining one sub-array with a "mixed" orientation. Here the calculation is correct, as it uses the mix of both I/V curves.
  • 4 years later...
Hi
I have three orientations and would like to use 1 invertor with 3 MPPT inputs for that but I am not sure how to assign a single invertor to all three subarrays.
I tried selecting the same invertor for each orientation with 3 MPPT but kept getting the following message: "you should define at least one string per inverter or MPPT input?
Can you please advise?
Kindly,
Hadi
In your Subarrays definitions, you have defined 3 MPPT in each sub-array. If so, you should indeed define at least 3 strings in each subarray.
Now in your case you have one string per Subarray, so that should define one MPPT input in each subarray.
