nico7904 Posted December 29, 2015 Posted December 29, 2015 Dear All,When I run the simulation for a stand alone system in PVsyst version 5.74, the Effective Energy at output of array, displayed in loss diagram in the report, doesn't match with the parameter EArUfix (Array nominal energy (at STC effic.) after remove all losses.For example for this project, I have 1165 kWh for the Array nominal Energy at STC.Here is the link for the screenshot of the Loss Diagram : https://photos.google.com/share/AF1QipNmgDl5SX7Q4J7SvH_rsFXStJQfwRAVO4Hy_9cTzWZX6Yfb6LX7BO0vFVlCkYwl0Q?key=T2ttUEpVd2xvYWxyWkRCMVpSOHFLSTJJTkM1YTRBIf I recalculate losses following percentages displayed on the loss diagram attached, I get :1165 - 0.037x1165 = 1122 kWh - After PV loss due to irradiance level1122 - 0.107x1122 = 1002 kWh - After PV loss due to temperature1002 - 0.019x1002 = 983 kWh - After module quality loss983 - 0.015x983 = 968 kWh - After module array mismatch loss968 - 0.012x968 = 956 kWh - After ohmic wiring loss956 - 0.186x956 = 779 kWh - After loss by respect to the MPP running779 - 0.015x779 = 767 kWh - After Unused energy (full battery) loss ...which is different of the Effective energy at the output of the array : 757 kWh.Could anyone explain that difference ?Thanks for your help
André Mermoud Posted December 29, 2015 Posted December 29, 2015 The difference represents 1.3% ... There may be some rounding uncertainty in the percentages, and the simulation procedure for stand-alone systems was not quite optimal in this old version 5.74 (there is some retro-action between the direct-coupled PVarray and the real battery voltage). With the next version 6.40 (to be released beginning of January 2016), the simulation of stand-alone systems has been deeply revised, and this balance is now quite correct (within 0.1 to 0.2%).
Li-ESS Posted October 10, 2024 Posted October 10, 2024 the latest try for your reference, this a grid connected system. The difference is about 0.61%. Please correct me, if any thing wrong in the process. PVsyst Version 7.4.8
dtarin Posted October 10, 2024 Posted October 10, 2024 (edited) I calculated 1,253,579,619.69, which is a difference of 0.047%, possibly because your waterfall is only showing the first decimal. It can be displayed to third decimal. 1436079647 1431771408 -0.30% 1315797924 -8.10% 1315797924 0% 1322376914 0.50% 1309153144 -1% 1280351775 -2.20% 1272669665 -0.60% Total 1253579620 -1.50% PVsyst 1254163298 0.047% Edited October 10, 2024 by dtarin
Li-ESS Posted October 15, 2024 Posted October 15, 2024 On 10/11/2024 at 1:38 AM, dtarin said: I calculated 1,253,579,619.69, which is a difference of 0.047%, possibly because your waterfall is only showing the first decimal. It can be displayed to third decimal. 1436079647 1431771408 -0.30% 1315797924 -8.10% 1315797924 0% 1322376914 0.50% 1309153144 -1% 1280351775 -2.20% 1272669665 -0.60% Total 1253579620 -1.50% PVsyst 1254163298 0.047% Thank you for your answer! Which let me find the right way: Now the difference is tiny: 1.87e-6
