How can I know how many panels there are per inverter in PVsyst?
I have a system with 6336 panels spilt between 2 sub arrays (both sides of a metal roof). I have 8 250kw inverters (4 on each side). How does the software assign panels to the inverters? Does it divide the 6336 panels in the system by the number of inverters so that each inverter has 792 panels assigned to it?
  • 3 weeks later...
Yes, within a sub-array, PVsyst will share the strings (not the number of modules) equally between the specified number of MPPT inputs.
Now if you have, for example 9 strings to be shared between 2 MPPT inputs, one will have 5 strings and the other one 4.
