I'm trying to do some sensitivities around different transformer NL and LL's using batch mode (much faster than running 20x runs w/ 8760s). However, there is only one transformer loss available in batch parameter inputs and it doesn't seem to relate to either value I had in the base model. I was using .14 and .9 and the batch mode is showing .01. Even if this is the summed value, I don't understand it as no load and load losses are not based on the same function. Is there a way to calculate these in batch mode that I'm overlooking?
Thanks,
Andrew
