Inverter Derating at High Voltage
purnaanshg
Hi,
If an inverter derates its power output after a certain high DC voltage level then how to provide that information in PVsyst so that it is taken into account during simulations and can be quantified from the results?
Example: A 100kW inverter has an MPPT range from say 400Vdc to 700Vdc with a 0.333%/Vdc derating beyond 700Vdc. If this inverter is used in a 1000V array with a high DC to AC ratio then the voltage of the array is bound to go beyond 700V. Does PVsyst take into account this kind of inverter derating into account during simulations?
Thanks
Purnaansh
  • 4 weeks later...
  • 5 years later...
  • 2 years later...
Hi, I'd like to follow up on this post as it's becoming more common to have inverters which derate power output as a function of dc input voltage. I don't understand the above response by PVsyst as to why this cannot be directly implemented in PVsyst (e.g., via additional inverter characteristic definition settings in the .OND file) in a straightforward manner. Please clarify it. Thanks.
Edited by kjs55
Slight editorial
  • 4 weeks later...
  • 1 month later...
  • 2 weeks later...
