kmullin Posted August 18, 2015 Posted August 18, 2015 I put in all the info for a ground mounted array using Solectria Inverters. when I did the simulation everything came up 0's. The loss diagram is normal till you get to the Inverter loss during operation that came up as -100.0% loss than everything after that was either 0% or +100% than -100% I am at a loss to why this did this. has never happened to me. Thanks for any help
André Mermoud Posted August 20, 2015 Posted August 20, 2015 Please check that your inverter is correctly defined. This usually arises when the efficiency curve is not well defined.
