Dennis Posted June 30, 2015 Posted June 30, 2015 Hi, in Germany we have (mostly) to set the cos(phi)=0.9. The SMA 25000TL "outout parameters" are tan(phi)=-9.95 to +9.95, so I can choose a cos(phi) from 0.1 to 1, right?Nominal AC Power defined as-active power [kW]Should in not be set to "Apparent power [kVA]" be default? The SMA 25000 TL datasheet says 25,000 kVA.Miscellaneous tools: Power facor:Again, [kVA] or [kW] for the "Nominal maximum power defined as"
André Mermoud Posted July 1, 2015 Posted July 1, 2015 Some SMA inverters have indeed a very large Power factor range. SMA claims that you can even specify Cos(Phi) = 0 (means that the inverter produces reactive energy during the night) but this doesn't make sense for the results of the diurnal simulation. This is the reason why we limited the Cos(Phi) to +/- 0.1. For the parameters in the PVsyst database, they have been specified by SMA people. Please ask them. However you are right: suppose you have a cos(Phi) of 0.1, the apparent power at Pnom = 25 kW (effective) would be 250 kVA, which means a quite irrealistic current ! The PNom limitation is usually corresponding to an output current limitattion, and should indeed be expressed in kVA.
Dennis Posted July 2, 2015 Author Posted July 2, 2015 Ok, I will write an e-mail to SMA. We use a "Pnom ratio >1.4", so we get some losses with delivering apparent power. Thats why I want to simulate it correctly. ;)
Francesco_SC Posted August 21, 2015 Posted August 21, 2015 Hi,I need to run a simulation with PF=0.95 leading but as default value in PVsyst is set lagging so in the report I get always results with pf lagging. Can please someone explain me whymany thanks!francesco
André Mermoud Posted August 21, 2015 Posted August 21, 2015 When defining the Power factor, you can also define the corresponding Tan(Phi). You can simply define a negative Tan(phi).By the way in terms of Apparent energy, the result is exactly the same.
Dennis Posted September 7, 2016 Author Posted September 7, 2016 Hello, me again...The new Huawei SUN2000-42 kTL can be set to 42 kW and 47 kVA -> 42 kW plus 5 kVA -> cos phi = 0.9Should I set in the OND file:Nominal AC power = 42 kWMaxium AC Power = 47 kW (this should be kVA)If I switch "output parameters -> Nominal AC power defined as" from kVA to kW the units under "Main parameters" are switching too. This is a bit confusing to me.
André Mermoud Posted September 15, 2016 Posted September 15, 2016 In this case you should specify PNom = 42 kW (in terms of energy). The Pnom = 47 kVA will be the power attained with a cos(Phi) of 0.9. However this cos(Phi) is not a basic parameter of the inverter, it is an operating parameter (only the limits for Cos(Phi) are a specification of the inverter). Therefore you cannot give a specification like (PnomApp[kVA]), as it will depend on the operating conditions. If the manufacturer specifies a PNom value in terms of Apparent power [kVA], this corresponds indeed to an output current limit. In this case the PnomEff[kW] will range between 42 kW (cosPhi=0.9) to 47 kW(CosPhi=0)NB: The PMax parameter in PVsyst in not related to the Power factor: it is a possible derate of the nominal Pnom value, when the temperature is sufficiently low.
