I have got a short question regarding the ground objects tool.
Is it possible to Place a Tracker system instead of normal modules with this tool?
This would be really helpful.
Dear user,
You can currently only generate simple PV tables when using zones of modules.
If you create the trackers yourself and want to place them automatically on the ground, then you can use "Tools > Position & tilt tables on scene" but this will only be relevant if you have one tracker per field.
If you have more than one tracker in a field, the result will not be correct as only the first one will be placed correctly.
NB: when using trackers at different altitudes, it will not be possible to define a backtracking strategy. In PVsyst, this is only possible with regular arrays of trackers. The Backtracking strategy cannot be applied in a simple way in not-regular arrays of trackers, as the orientation of each tracker would be different (according to the neighbours), and should be calculated independently.
