The Global incident is just the result of the transposition of your meteo data (GlobHor) to your tilted plane.
With tracking arrays, when using backtracking, this could change when you change the width of the trackers or the pitch between trackers, because the backtracking conditions will vary.
In any other case, the Incident Global has no relationship in any way with the rest of the system, such for example the AC capacity.
