Is there a way to model my project assuming a single tracker is broken amongst the operating trackers? The resource difference is not a problem but I'm not sure how to calculate the impact from shading losses.
Thank You,
Emily
You should do 2 different tracker arrays on each side of the broken tracker, and define a fixed rectangle for the broken tracker.
However you will not be able to put PV modules on the broken tracker: you cannot mix fixed and tracking PV fields.
