I constructed a scene and saved it. But when I am trying to run the table for the shading scene its showing the error as No shading scene defined. Could you please help me out on this issue.
I am using version 6.34.
Thank you,
Jaya
I can't say anything.
Please check that the shading scene is really present in your calculation version (i.e. behind the button "Construction/Perspective"), and it is "operationnal" (i.e. try the button "Shadows animation aver on day" bottom left).
Hi Andre,
The shading scene is present and I did the shadow animation, still its showing as No scene.
Thank you,
Jaya
Hi Andre,
I figured out the issue. We should not close the shading scene window on the X mark at the top right corner, it should should be closed from the close option under file menu in the shading scene.
Thank you,
Jaya
