I am trying calculate monthly soiling loss as a % using the monthly losses in kWh. I was using the equation (kWh Loss/(kWh Loss + Energy Injected into Grid)). However, I found that if I use this same equation on the Annual Soiling Loss and Annual Energy injected into Grid, I do not get the same % Loss that is in the Loss diagram. In this situation, I have the following annual values:
Soiling Loss (from output table): 45255 kWh
Energy Injected into Grid (from Loss Diagram): 1289957 kWh
Soiling Loss (from Loss Diagram): 3.1%
45255/(45255+1289957) = 3.39%
I also tried dividing the loss by the Nominal Array Energy at STC (1627062 kWh), which gave 2.78%
Could you tell me what value I should be using to find Soiling Loss as a percent?
Thanks
In the version 5, the soiling loss parameter (to be defined in the "Detailed losses" and appearing in the first page of the report) was defined as a percentage of the STC energy value.
Now during the simulation, the corresponding energy loss is indeed calculated as a percentage of the STC energy as specified.
But the result on the loss diagram is referenced as a percentage of the remaining energy just before the loss, therefore a slightly different percentage value.
In the versionn 6, it is accounted in the optical losses, and is a loss by respect to the remaining irradiance (after shading and IAM losses). The value on the loss diagram is identical to the specified parameter.
  • 2 years later...
  • 4 weeks later...
