rebecca.dunn Posted June 17, 2014 Posted June 17, 2014 Hi,We are trying to obtain hourly output files for multiple years of meteo data from batch mode.We have run the batch mode with several years of meteo data, by specifying lines likeSIM_1; CP2010.MET;N;1.22MWp_1.06MVA_0.3073GCR_FT;;SIM_2; CP2011.MET;N;1.22MWp_1.06MVA_0.3073GCR_FT;;in the fileCP_Project_BatchParams2.CSVBut even though we tick the boxes for "Create hourly files" and "Always produce calculation version files", under "Save mode" in "Parameter specification", we don't get hourly files. We only get a summary of annual values inCP_Project_BatchResults2.CSVIs there a way to obtain hourly output for multiple years of meteo data without running them one-by-one?Thankyou,Rebecca
André Mermoud Posted July 9, 2014 Posted July 9, 2014 When in the batch mode definitions, you tick the box "Create Hourly Files", you will be prompted to define the variables to be listed in the hourly file. Then, in the parameter specification list in EXCEL, you should have a column "Create Hourly File" / "File name".In this column, you should define a filename for each desired hourly file (usually with CSV or TXT extension for an easy reading in EXCEL).
Søren Bækhøj Kjær Posted January 6, 2015 Posted January 6, 2015 Dear PVsystyou wrote: When in the batch mode definitions, you tick the box "Create Hourly Files", you will be prompted to define the variables to be listed in the hourly file. Then, in the parameter specification list in EXCEL, you should have a column "Create Hourly File" / "File name".In this column, you should define a filename for each desired hourly file (usually with CSV or TXT extension for an easy reading in EXCEL). I'm using the version 6.32, and I don't get the prompt, thus I cannot get the hourly results when doing batch-simulations, only the yearly summary.What to do? (I have attached the batch parameter filer for inspection).SRSøren Bækhøj Kjær(new to PVsyst)
André Mermoud Posted January 10, 2015 Posted January 10, 2015 When defining the batch mode, you should tick "Create Hourly File". If you do that, when exiting the batch mode dialog, the dialog for the definition of Hourly files appears after the message : "You have to define the contents of your hourly file". However you can also define the output CSV file by the button "Output file".On the batch parameters defintions sheet, you will have to specify a filename for each hourly file you want to create.
CalSolar Posted February 8, 2015 Posted February 8, 2015 (edited) I too have not been able to generate hourly files using the instructions you gave above. I am working off of version 6.34 on a Windows 7 machine.Is this function currently working? Edited February 17, 2015 by CalSolar
CalSolar Posted February 8, 2015 Posted February 8, 2015 (edited) I think their maybe a bug in the current version of this feature. After following your procedure:When defining the batch mode, you should tick "Create Hourly File".If you do that, when exiting the batch mode dialog, the dialog for the definition of Hourly files appears after the message : "You have to define the contents of your hourly file".However you can also define the output CSV file by the button "Output file".This will not generate hourly files despite providing a file name for each simulation line. The following batch file is generated by PVsyst.Ident;Create hourly;Nb strings;Simul;file;in parall;Comment;File name;;;;;SIM_1; N;2560; Edited February 17, 2015 by CalSolar
André Mermoud Posted February 16, 2015 Posted February 16, 2015 I don't know what you are doing.I have just tried creating files in batch mode with Version 6.34, and this works quite well.Here is the script of my test: Batch command script in EXCEL
CalSolar Posted February 17, 2015 Posted February 17, 2015 I now know what the problem was. I was not including file extensions in the file name.
