SolarJ Posted May 14, 2014 Posted May 14, 2014 Since upgrading to v6.23 I have not been able to print to either my Blubeam PDF printer or my native PDF printer. Please advise ASAP
jfish Posted May 15, 2014 Posted May 15, 2014 I have had this problem as well but have found a (temporary) fix. It appears that V6.23 will now only print to the default printer as identified by your PC.In order to change printers since upgrading to 6.23, I first go and change the default printer in Windows then open PVsyst and print the report.If you change your default printer to your PDF compiler, it should work for you.This bug needs to be fixed soon though since this is an unnecessary pain for the user.An odd bug, funny how these things pop up from revision to revision with seemingly no connection to stated upgrades.Because of odd bugs like this, I am now in the habit of always doing a parallel upgrade with each revision.
SolarJ Posted May 15, 2014 Author Posted May 15, 2014 Thank you Jfish! It's a very annoying Bug. PVsyst please fix ASAP.
