Is there a way to keep the AC and DC % losses fixed to a certain value while I change the DC/AC Ratio during a Batch simulation run?
Thank You
In the DC part: you should check the "Default" checkbox.
And if the default value doesn't meet your requirements, you can modify it in the "Hidden parameters", "System design parameters", item "Default wiring resistance loss ratio".
For the AC part, there is no default and I don't see how to specify a stable loss whatever the power in the present state.
