Nicolas0202 Posted November 7, 2025 Posted November 7, 2025 Hi is it possible to set or simulate that during 8-10AM the plant will priotize to charge the battery and not inject to grid?
Robin Vincent Posted November 10, 2025 Posted November 10, 2025 Since PVsyst 8.0.17, you have the possibility to use the "power shifting" strategy in Grid storage. If you do so and select "Fixed charging power before exporting" you can set it to charge as much as possible between 8 and 10. If the charging power is higher than the PV production, nothing will be injected to the grid. The main limitation for the moment is that any value you set will be applied every day for the whole year. Time series import should be available starting from PVsyst 8.1.0
