Ziad Posted November 4, 2025 Posted November 4, 2025 Hello , I have a cad file containing contour lines and points of a site, I extracted the data from the cad file into a csv file containing X,Y,Z coordinates of all the points in it and imported it into PVsyst scene as a ground object , but the problem is that when I place the PV tables over it ,some of them are not placed properly
Muhammed Sarikaya Posted November 5, 2025 Posted November 5, 2025 Dear Ziad, Can you also try this feature: Tools → Automatic altitude (see below)? Select your entire table first, then enable this feature. On the right, try setting 1 meter or more, choose Lowest point, and click Set automatic altitude. Let me know if this solves your issue. Regards,
Ziad Posted November 7, 2025 Author Posted November 7, 2025 thanks for the reply, I tried it but it didn't solve the issue
Muhammed Sarikaya Posted November 10, 2025 Posted November 10, 2025 Could you please send us your project along with the 3D file at support@pvsyst.com Regards,
