Evan_CSSI Posted April 7, 2014 Posted April 7, 2014 I'm trying to import RETScreen data on PVsyst 5.72 for the location of Baker Lake, Nunavut, Canada. I can save the site file but when I go to execute the meteo I get an error that won't allow me to proceed, "Value must lie between -20 and 50".This error is referring to the temperature column of my data I believe. Because the location is so far north the temperatures for winter months go as low as -32°C.Is there any workaround for this or am I simply not able to import this data because it's too cold!?Thanks!
Bruno Wittmer Posted April 8, 2014 Posted April 8, 2014 There is a parameter to define this limit.In the main window menu choose 'Preferences -> Edit hidden parameters'Look for the category 'Miscellaneous'. There you can set 'Minimum monthly ambient temperature' (the default is indeed -20 °C).
