AlexBackCwbBrazil Posted August 22 Posted August 22 (edited) Dear @LL , Since which version of PVsyst it is presented in the report the correspondent electrical mismatch losses? Our doubt is why it is not presented in an report from version 7.2.18 and since it made available by the tool. Below some pictures to better ilustrate the question. Thanks in advance! Report that is raising the doubt: Desired report (example): Edited August 22 by AlexBackCwbBrazil
dtarin Posted August 27 Posted August 27 Electrical shading loss has been around for a long time. It is likely the 7.2 report was run on linear shading, or the site was modeled perfectly flat with backtracking enabled and no shading objects present to cause electrical shading loss.
AlexBackCwbBrazil Posted August 29 Author Posted August 29 On 8/27/2025 at 12:46 AM, dtarin said: Electrical shading loss has been around for a long time. It is likely the 7.2 report was run on linear shading, or the site was modeled perfectly flat with backtracking enabled and no shading objects present to cause electrical shading loss. Thanks!
