Hello everyone,
When I enter the parameters for a self-consumption system with storage, an error appears that says: 'Inverter Definition: The output nominal power is not defined for a Sungrow battery with AC coupling.' I don't know what parameters I need to enter or where this parameter is located.
Thanks in advance
This concerns the inverter at the output of the battery pack.
On the next page "Self consumption", please define the "Max. discharging power".
As a first step, you can ask the default value proposed by PVsyst according to your consumption profile (checkbox on the right).
Sorry, I can't understand that.
Please send us your full project, using "Files => Export project" in the main menu.
Send it by e-mail to  support@pvsyst.com, and tell us in which variant you have this problem.
Thank you for sending your project.
However it doesn't show the same output as you have shown here:
The message tells you that the maximum discharging power is highly undersized. Your load definition has many hours with a load demand of around 21.3 MW, including during night, and you limit the discharging power to 10 MW.
When I specify 22 MW as a discharging power, as you did in your previous message, I don't see any error nor warning anymore.
