sirihar Posted March 11, 2014 Posted March 11, 2014 Hi, how does PVsyst (version 6.20) handle the fact that not all inverters are able to distinct between local and global MPPs? For exampel: OptiTrac Global peak is a MPPT/algorith implemented in new inverters from SMA. Older ones, like Sunny Mini Central 5000A, does not have this function, instead it uses a conventional MPPT which cannot "see" whether a MPP is the true (global) MPP or a local one? Operation at a local MPP will decrease the power outout from the potential output. But I am not sure how likely it is that an inverter actually will operate the system at a local MPP. It seems to me that PVsyst don't consider the issue - am I right? Best regards, Siri
André Mermoud Posted March 12, 2014 Posted March 12, 2014 In the "Module Layout" calculation, PVsyst always takes the best MPP point indeed.I don't see how to do differently: how to decide which maximum is really taken by the inverter ? By the way this represents a very low energy uncertainty: - the shading situations with 2 MPPt are not very significant: they only concerns the situation when the diffuse component is higher than the beam component, due to particular shading dispositions. - for usual systems, the full electrical shadings loss (module layout calculation) is less than a very few percents during the year. The additional loss would be a fraction of this loss. - the power difference between both points is not necessarily very high.
