V8.0.11 Bifacial w/ Fixed Tilt Plane, Flush to Roof mount via Polygonal Fields - Not compatible w/ bifacial 2D model
Hello Team,
I am using V8.0.11  and trying to model Bifacial w/ Fixed Tilt Plane, Flush to Roof mount via Polygonal Fields - this is not compatible with bifacial 2D model - is this a bug or is there some way that I could model this irregular layout with bifacial (see snip of model)?
I realize this flush to roof the bifacial factor will be very small, but the client is determined to confirm modeling this bifacial gain..
Any suggestions and thoughts are greatly appreciated, much thanks in advance!
ie would converting to a Rectangular PV Array and trying to line up/match this jagged flush roof layout (as much as possible) allow the bifacial 2D model - or something else be a workaround?
Thanks, Mike
