I am constructing a PVsyst simulation with a topographic TIFF sheet and a Google Maps image in the background.
There seems to be an error, as you can see in the picture.
This concerns a hill that is being covered.
What exactly does the error message mean, and what can I do to resolve it?
Thank you.
Averaged orientations have a fixed tolerance on the maximum angles difference between the fields planes and the orientation's tilt and azimuth.
This means for example that the field #12175 in your scene has a difference of 8.4° with its averaged orientation. When this value is above a certain threshold, PVsysts considers that the computations will be less relevant.
You have 2 options:
- move some fields in a new orientation: select fields in the Scene objects list, right click on the selection and click on 'Create orientation from the selection'
- increase the tolerance 'Maximum orient. difference for defining average (spread) orientation' in 'Other limitations' tab of the project settings
  On 3/18/2025 at 4:08 PM, Jéremie Bernier said:
You have 2 options:
Expand
Thank you very much, that is the answer I needed.
