Muhammad Zubair Posted February 24, 2025 Posted February 24, 2025 Hello, I am working on a project in which the h2p file is generated from Helios3D. When it is imported in PVSYSt, it gives an error as below. I have only one orientation in the project with only 1 tilt and azimuth. It says that the number of PV modules in the 3D scene is less than the number of modules in the orientation part. However, the table area in 3D scene is bigger than the area in PV System. Could you please provide a solution to this problem?
