How I could add the PRTemp, TarrWdt and PR bifacial on Report?
I understand that at report options I can add the PRTemp ratio in the PDF report, but I don't know how add the other 2 variables in this document.
When editing the report, please open "Report options" in the menu.
Here you have the opportunity of defining the values you want in the monthly table.
The TArrWtd value is not available on the report. You can get in in the detailed results, button "Tables". Here you can generate a table of monthly values with any chosen variable (option "Custom table").
