ashkanemami66 Posted February 2, 2025 Posted February 2, 2025 Hi dear As you know, the new generation of inverters introduced to the market are hybrid. However, unfortunately, in the PVsyst software, I could not find a place to enter the battery input specifications for the inverter. For example, the acceptable battery voltage range for the inverter or the maximum battery charging current by the inverter. Can anyone provide guidance on this?
ashkanemami66 Posted February 2, 2025 Author Posted February 2, 2025 Just now, ashkanemami66 said: Hi dear As you know, the new generation of inverters introduced to the market are hybrid. However, unfortunately, in the PVsyst software, I could not find a place to enter the battery input specifications for the inverter. For example, the acceptable battery voltage range for the inverter or the maximum battery charging current by the inverter. Can anyone provide guidance on this? @PVsyst forum
Muhammed Sarikaya Posted February 3, 2025 Posted February 3, 2025 Dear, Hybrid inverters are indeed not taken into account in PVsyst. However, you can run a simulation with storage by defining the self-consumption profile. This simulation will show the energy balance, including the energy injected into the grid, the energy stored in the battery, and the energy used by the user. I invite you to watch our tutorials explaining how to perform this type of simulation:
Nick Rouse Posted October 7, 2025 Posted October 7, 2025 It is suggested that you deal with systems using hybrid inverters by defining a battery system with a consumption profile. You still have to select an inverter. Do you have to try and find a non-hybrid inverter that has all the characteristics such as number string inputs, number of MPPT's min and max voltages as the hybrid inverter you want to use?
