MicheleANE Posted January 30, 2025 Posted January 30, 2025 Dear PVsyst team, We usually simulate quite complex 3D scenes with many different orientations and in some cases there is only 1 or 2 arrays for an orientation. In these cases PVsyst doesn't allow us to simulate the bifacial part because the pitch is not omogeneous enough or it is 0 in the 3D scene. I tried using the "Pitch defined by user" and "Number of Sheds defined by user" parameters and defined parameters similar to other orientations because in the 3D these arrays are close to other arrays with similar parameters. Even doing this the software doesn't let me simulate. Is there anything I can do to run it anyway? Would be possible to change this behavior so in case we defined the pitch and sheds number as "defined by user" the simulation will use this parameters disregarding the actual 3D? Best regards
