hritik Posted January 28 Posted January 28 While importing the PV module PAN file and updating the IAM values in it, the default values are being applied instead of the user-defined ones. The user-defined values are only being applied when I manually select the user-defined profile. However, in earlier PAN files, the user-defined values were automatically applied from the PAN file. Please suggest why this is happening and what corrective measures can be taken to resolve this issue.
André Mermoud Posted January 29 Posted January 29 The user-defined state is shown according to the definition present on your PAN file (when you saved it). If it is de-activated on the PAN file, it will appear as de-activated.
André Mermoud Posted January 30 Posted January 30 You define the option you want, and when clicking OK, you will be prompted for saving your PAN file with your choice.
hritik Posted January 31 Author Posted January 31 How can I Change the state in .PAN file instead of doing it into the pVSYST and saving.
André Mermoud Posted February 4 Posted February 4 The PAN files are meant for internal use within PVsyst. They obey to some internal coherency constraints. We don't ensure support about modifying them externally.
