robin_earth Posted January 23, 2025 Posted January 23, 2025 How can i make a simulation whit a string that is strongly oversized? in reality this is it and it works on the inverter but not on PVSyst?
Muhammed Sarikaya Posted January 27, 2025 Posted January 27, 2025 Dear Robin To solve this issue, you need to: Click on "Settings". Then go to "Edit advanced parameters". In the search bar, type "Oversized". Modify the parameter "The inverter power is strongly oversized" with the limit value you want to set. Below, you will find an explanatory illustration. Best regards,
