Irakli Bezhuashvili Posted January 20, 2025 Posted January 20, 2025 I am using inverter "SUN2000-115KTL-M2" which has maximum AC power 125 kva at cosf 1 and 115 kva nominal power. I am going to configure the inverter on maximum power 125 kva. How should I reflect this in PVsyst, because PVsyst calculates generation on 125 kva? Thanks in advance
Muhammed Sarikaya Posted January 20, 2025 Posted January 20, 2025 Dear Irakli, I don't quite understand your question. Could you be more specific about what exactly you want to do? Regards, Muhammed Sarikaya
Irakli Bezhuashvili Posted January 20, 2025 Author Posted January 20, 2025 48 minutes ago, Muhammed Sarikaya said: Dear Irakli, I don't quite understand your question. Could you be more specific about what exactly you want to do? Regards, Muhammed Sarikaya I am using the SUN2000-115KTL-M2 inverter, which has the following specifications: Maximum AC Power: 125 kVA (at cosφ = 1) Nominal AC Power: 115 kVA I plan to configure the inverter to operate at its maximum AC power of 125 kVA. However, I noticed that PVsyst uses the nominal power (115 kVA) for its calculations. Could you please advise how I can reflect the maximum power configuration (125 kVA) in PVsyst to ensure accurate generation calculations?
Muhammed Sarikaya Posted January 21, 2025 Posted January 21, 2025 Dear Ikarkli, In the .ond file, you can find the "Output Parameters" tab and click on the "Allows Overpower" checkbox, as shown below: This means your inverter can reach 125 kVA at 25°C. Is this what you were looking for? Regards, Muhammed Sarikaya
