Stewart Posted January 9, 2025 Posted January 9, 2025 I'm new using PVsyst and I dont know how my 3d shading will be the same in my system design like this. what I will do so my PVsystem will be the same in my 3D scene. Thank you in advance
Jéremie Bernier Posted January 9, 2025 Posted January 9, 2025 Hello, can you please confirm if you started by setting up the system part and you want now to design the scene with PV modules and shading objects? Or if it's the other way arround? That is, you have already your scene (either manually created or imported from a 3d file) and need guidance so as to define the system part? If you want, you can send the exported zip file of your project (Project / Export the project) and send it to support@pvsyst.com so we can have a look at it
Stewart Posted January 10, 2025 Author Posted January 10, 2025 Hi Jeremie, Thank you for your response, I usually made the system part first then I create the 3D scene design and I always having a problem making the design reflect to the system design.
Jéremie Bernier Posted January 10, 2025 Posted January 10, 2025 Hi. Please consider following pages that may help you in understanding how to match your design with the system layout: https://www.pvsyst.com/help/project-design/shadings/near-shadings-3d-construction/object-types/pv-fields.html https://www.pvsyst.com/help/project-design/orientations-in-v8/system-and-3D-attributions.html?h=definition
