RobSolar Posted December 16, 2024 Posted December 16, 2024 You can actually put 2 digits values and I think PVSYST actually considers 2 digits values, but the value is rounded as soon as you exit the Detailed Losses window, making it very confusing.
Robin Vincent Posted December 16, 2024 Posted December 16, 2024 Actually, it is even trickier than that. For both values, changes are detected if any of the 1st 4 characters is changed. It usually means 1 digit for module quality (the "-" counts as a character) and 2 digits for the LID. Then, if the value is less than 0.1 point different from the default, it is set to the default value. The final value is then stored and, as you mentioned, only 1 digit is displayed. This is obviously not ideal, and we should harmonize the behaviors and make sur the number of digit displayed matches the number used. Nevertheless, such an accuracy (1/10000) is definitively not necessary in the 1st place.
