rock_fire07 Posted December 2, 2024 Posted December 2, 2024 Hello. There is a problem with the configuration of the bifacial model when working with two different orientations. In the first orientation, I can modify any parameter, and the graphs update accordingly. However, when I change parameters for the second orientation, such as the height above ground, the graphs and representations do not update. For example, I set the height above ground to 1.2 m, but in the representation, it remains at 2 m. Best regards.
Jéremie Bernier Posted December 2, 2024 Posted December 2, 2024 Hello. When you change a parameter value, just click in another field so the new value is taken into account right away. Also, I did the test - changed the Heigh above ground value - and it's been reflected after a few fractions of second in the graph. Please try again. Do you observe same behavior with other parameter - for example Pitch?
