in the "Near shading" menu, when creating a a PV field using the zones, there is an absolute limit on the slope of the ground fot positioning of the different PV tables?
Thanks in advance
Hello, there is no such limitation in the fields zone creation tool. If you encounter any issue, don't hesitate to send the export of your project to support@pvsyst.com along with an explanation of what you're trying to achieve. Regards
