The difference between the azimuth of the field and of the average orientation too high error
Hello Team,
As you can see below. I am getting the error for the differnce between the azimuths as well with the error average orientation is too high. As the average is in minus, how I can i change the other limitations in the Project setting.
Thank You.
Regards,
Pranav
  • 4 weeks later...
I have a similar error, but my question is what value to introduce in the parameters in the case I have both negative and positive values (I am working with and EW system). When I introduce a negative value in the parameters, the error only shows for those field with positive values, and viceversa.
Thank you for the help!
Hello NGD. The parameter is a positive value. The absolute value of the angles difference is checked against this parameter.
My guess is that in the first case (15 - 12.6) you set a value that was sufficient to accept this difference, but not in the second case (109.9 - 93.6 = 16.3) Please check again
Edit: Your error actually refer to parameter 'Tilt Spread Max'
  • 2 months later...
Good Morning.
I am using PVsyst 8.0 and I am geting the same error. However seems that in advanced project settings the parameter Param_Azim Spread Max is not anymore. How is the procedure with the new version.
image.thumb.png.81ce3f2f8e0bffbc129fe43f86b6f1ed.pngimage.thumb.png.467d3a074799f477f818b1afcfc4882b.png
