We had a layout that had no errors in PVsyst 7.4... We moved to PVsyst 8 and have the following error and not sure how to resolve. Included is a png file of error but will type it as well.
44 fields in error, the first one being: Field ##26, "Table Row #346 Col #29"; The angle between the field and the average orientation (10.7grees) is too high. Any help resolving this issue would be appreciated.
  • 2 months later...
I have the same problem in version 8.0.5, even once I have changed the value of maximum spread of tilts between planes.
I appreciate some help.
I have solved by myself. The solution was in changing the spread of tilts in the "Project settings" and not in "Edit advanced parameters". Althought I've previously changed this parameter in advanced parameters, as seen in previous responses on this thread.
Hope this helps others with the same problem.
KR.
