abcpvpv Posted August 18 Share Posted August 18 in dwg ,I have set the material for the pv faces. dwg -->fbx Autodesk FBX converter , fbx--> DAE in pvsyst , import DAE , there is no material. after importing DAE. the "Transform to PV faces" is gray . why ? what should I do. Can you give detail steps of importing dwg into pvsyst ? Link to comment Share on other sites More sharing options...
Jeremie Posted August 22 Share Posted August 22 Hello, The first step is to determine whether the material information is missing from the DAE file or if it is being misinterpreted by PVsyst. To assist you better, could you please provide the DAE file along with the original DWG and FBX files? Thank you. Regards, Link to comment Share on other sites More sharing options...
abcpvpv Posted August 26 Author Share Posted August 26 i have sent them to support@pvsyst.com Link to comment Share on other sites More sharing options...
Jeremie Posted August 27 Share Posted August 27 Hello, The following pvsyst help https://www.pvsyst.com/help/index.html?sketchup.htm states that "Using FBX Converter can result in some objects being slightly misplaced in the resulting DAE file" I used sketchup to import your dwg file and then export it as dae file. In turn I imported this dae file in pvsyst and managed to see the PV objects Regards Link to comment Share on other sites More sharing options...
abcpvpv Posted Thursday at 02:08 PM Author Share Posted Thursday at 02:08 PM SketchUp is paid software,You need to spend money to buy it。 is there any free software that can replace it? Link to comment Share on other sites More sharing options...
abcpvpv Posted Thursday at 02:10 PM Author Share Posted Thursday at 02:10 PM On 8/22/2024 at 6:06 PM, Jeremie said: Hello, The first step is to determine whether the material information is missing from the DAE file or if it is being misinterpreted by PVsyst. To assist you better, could you please provide the DAE file along with the original DWG and FBX files? Thank you. Regards, I've been emailing you for 1 month now. Have you found the reason? Link to comment Share on other sites More sharing options...
Jeremie Posted yesterday at 07:11 AM Share Posted yesterday at 07:11 AM Hello, the help link i gave you states that the following file format are supported for import in PVSyst: - DAE : The Collada file format can be exported from many CAD software as it is an open format. It is available as an export format in Sketchup free version. - 3DS : Less used but still an export option in many tools - PVC : PV Collada file, open-source format derived from DAE format to include data about the PV modules and tables Link to comment Share on other sites More sharing options...
