Ahmed Hasan Posted August 11, 2024 Posted August 11, 2024 Greeting All, I am asking, How to enable charging battery storage from grid during night in or in case of cloudy day in PVsyst? Thanks in advance
André Mermoud Posted August 12, 2024 Posted August 12, 2024 This is not possible in PVsyst in the present time. This is indeed not pertinent in most cases: why charging the battery if power is available from the grid when necessary ? Now there may be particular cases where this cous be useful. For example: - in case of very weak grid, it could be useful for keeping a minimum of charge in the battery, for ensuring consumption in case of grid failure. - If you want to store energy during low tariff period, for restituting it during high tarif period. However this may be done in any system, even without a PV production. This is not considered in PVsyst.
vptamara-ebi Posted Monday at 07:27 AM Posted Monday at 07:27 AM Hello, I am trying to simulate a system on PVsyst where the battery storage is charged from the grid at certain times. Has this feature been added to PVSyst?
André Mermoud Posted Monday at 01:31 PM Posted Monday at 01:31 PM Sorry, this storage strategy - i.e. storing PV energy for a restitution in the evening - is not yet implemented in PVsyst. This should be done within some few months. I the meantime, if the battery has full priority at the beginning of the day, or charges with a fixed power, we can propose a workaround for at least evaluating the result. You could use the "Self-consumption" option, by defining a consumption corresponding to your foreseen reinjection power from 6pm, for a sufficient duration in order to discharge the whole battery (and null the rest of the day). Then you can consider the energy delivered to the user as the energy to the grid. You can ignore the missing energy.
vptamara-ebi Posted 5 hours ago Posted 5 hours ago I think you missed my question. How do i specify in my PVSYST model that the battery is capable of being charged by both the PV and via AC electricity from the grid?
vptamara-ebi Posted 5 hours ago Posted 5 hours ago On 8/12/2024 at 11:30 AM, André Mermoud said: This is not possible in PVsyst in the present time. This is indeed not pertinent in most cases: why charging the battery if power is available from the grid when necessary ? Now there may be particular cases where this cous be useful. For example: - in case of very weak grid, it could be useful for keeping a minimum of charge in the battery, for ensuring consumption in case of grid failure. - If you want to store energy during low tariff period, for restituting it during high tarif period. However this may be done in any system, even without a PV production. This is not considered in PVsyst. is it possible in PVsyst now? if yes, how?
André Mermoud Posted 1 hour ago Posted 1 hour ago I think you missed my previous answer, three days ago. I wrote : "this storage strategy - i.e. storing PV energy for a restitution in the evening - is not yet implemented in PVsyst." Is it not sufficiently clear ?
