pobrien Posted January 10, 2014 Posted January 10, 2014 I am no longer able to create a PDF or even print the Results Reports from PVsyst. When I click on the print button the Report page closes / disappears. It used to be that a window for print window would pop up in the foreground and I could then select to print to PDF. The window still pops up in the foreground but sine the Report closes there's nothing to print or create a PDF from. I'm using version 5.72. Help! Thanks.
André Mermoud Posted January 13, 2014 Posted January 13, 2014 There is probably a problem with the driver of your active printer. Please try simply to change the default printer in your Windows installation. If this doesn't work,you can download the free tool PDFCreator (to be installed as a printer):http://www.pdfforge.org/products/pdfcreatorAnd choose it as Default printer. To my knowing this works in any case.
