abcpvpv Posted June 10 Share Posted June 10 there are more than 4000 pv 3dface in dwg. 1 impert dwg into sketchup 2 export to dae 3 import dae into pvsyst most of the them are ok. but some of the pv 3d face is splited to two triangle. why ? if i delete 3500 face. only export 500 faces (include the wrong faces just now) to DAE. then import 500 faces into pvsyst. all of them is ok.....。they are not splitted to 2 triangle. Link to comment Share on other sites More sharing options...
Stéphane Posted June 10 Share Posted June 10 Hello, Please send both files (the one that is working and the one that is not working) by email at support@pvsyst.com so that we can have a look. Thanks in advance. Link to comment Share on other sites More sharing options...
Mikel Escos Posted 15 hours ago Share Posted 15 hours ago good afternoon, I am also having the same problem. Some of the tables are generated as objects. I think this may be because in sketch up pro the tables are generated split (they are not in the same plane). How can I solve it? Link to comment Share on other sites More sharing options...
