hritik Posted May 21, 2024 Posted May 21, 2024 When comparing different manufacturers for a particular site, I obtained the results which are varying. Are there any default parameters for PV loss due to irradiance levels and PV loss due to temperature in PVSYST? On what parameters do these factors depend? Is it possible to get gain due to loss from irradiance levels? What should be the ideal values for Module quality losses?
dtarin Posted May 22, 2024 Posted May 22, 2024 15 hours ago, hritik said: When comparing different manufacturers for a particular site, I obtained the results which are varying. Are there any default parameters for PV loss due to irradiance levels and PV loss due to temperature in PVSYST? On what parameters do these factors depend? These come from the PAN file, resistance values/low-light performance, temperature coefficient Is it possible to get gain due to loss from irradiance levels? Not sure what this means What should be the ideal values for Module quality losses? There are no ideal values, depends on the one doing the simulation
