What is the source of the .ond files in the pvsyst database? are these made by pvsyst or the manufacturers?
For a project I have the following 3 .OND files
2019 .OND name implies version 6.8 in pvsyst
2022 .OND by default in the pvsyst database
2023 .OND received directly from the manufacturer
My problem is that the 2019 and 2023 are the exact same, both versions have the same values and ignore stuff such as maximum current mppt.
Meanwhile the one in the pvsyst database as an incorrect current which when used would lead to weird capping losses.
Are the .OND files in the database made by pvsyst themselves?
  • 1 year later...
Quote
The 2022 file in your database having an incorrect current is likely due to how PVsyst interprets unspecified parameters.If a manufacturer provides a datasheet but leaves the Maximum Input Current blank or ambiguous, PVsyst might calculate it using a default formula:
I_{max} = Pnom,DC / Vmin,Pnom
If the manufacturer's datasheet and the PVsyst-calculated value don't align, you get the weird capping losses clipping you are seeing.
This parameter  "Maximum current per MPPT" is indeed quite correlated to the "Minimum voltage for attaining PNom".  See the help   https://www.pvsyst.com/help/component-database/grid-inverters/grid-inverters-main-interface/grid-inverters-main-parameters/index.html#input-side-dc-pv-array
Now if this is specified, PVsyst will apply this cutrremt limit during the simulation. But this rarely produces "Inverter losses due to current overload", as this limit is most of the time preceded (masked) by the Power overload limit. See the Help   https://www.pvsyst.com/help/physical-models-used/grid-inverter/inverter-operating-limits.html
If the limit is not specified, it is obviously not applied.
Now this limit is not always well "understood" by the manufacturers who submit their data, nor well defined in the datasheets. Sometimes we have to add this information afterwards in the database.
