David Bourdon Posted February 28, 2024 Posted February 28, 2024 Good Morning PVsyst Team, A quick question regarding the export of the simulation variables. Is it possible to define a list of predefined variables that we want to export ; not only those applicable within the simulation, but a determined list with specific variables (even if not used). By default PVsyst will not propose the variables that are not applicable within the project (i.e : horizon if no impact ; HV lines if not defined : HV transformers if not defined, etc...) . In order to develop our methodology, we would like to create an export which has always the same number of columns within the CSV file. Is it something possible within the software ? We were not able to find an option to force the extract of specific variables. Thank you in advance
dtarin Posted February 28, 2024 Posted February 28, 2024 Yes, under advanced simulation > output file, you can select the variables on the right you want, then save that as a template. You can have multiple templates.
