Alberto Cerrone Posted October 12, 2023 Posted October 12, 2023 Hello , pvsyst not let me use bifacial in my simulation , i have imported the 3d scene from autocad, the pitch is regular. Pvsyst say i have to use unlimited sheds, but if i use unlimited shed it says that he will do a shadow calculation not based on the 3d scene. Pls help. Plus is possible to edit multiple pvtables insted of manually do it one one for adjust the modules configuration?
Stéphane Degré Posted October 13, 2023 Posted October 13, 2023 Dear Alberto Cerrone, To modify multiple objects at the same time, you can go to "Tools > List and management of objects". Then you select the objects you want to modify and you do the modification on one of them. It will apply to all selected objects. Regarding the bifacial issue, I suggest you send us your project at support@pvsyst.com so that we can have a better look. Thanks
Alberto Cerrone Posted October 13, 2023 Author Posted October 13, 2023 I will send asap i am done with the project. But i not find the option u mentioned useful. i have something like 2174 object that are pv string. now i have to set them as portrait 14x2 but i not find any option to do it for all at once , i am doing it one on one and it is taking days
