M0GLI Posted October 21, 2013 Posted October 21, 2013 What is the significance of Daily input output diagram of PVsyst?
André Mermoud Posted October 21, 2013 Posted October 21, 2013 Each point of the graph represents the production of one day. On the x-axis, you have the daily irradiation in the collector plane [kWh/m2/day]On the y-axis, you have the system's production [kWh/day]For Grid-connected systems, this is usually very linear (points below correspond to days with special losses like shadings or system unavailability). You have often a curvature in the upper part, corresponding to higher operating temperatures in summer. For Stand-alone or pumping systems, it is much more instructive: a plateau indicates that the storage is full: if the plateau is low (begins very early), your storage (battery or water tank) is not sufficient: for many days the production is limited by the full filling of the storage. A well-sized storage will give a little plateau in the upper part of the graph.
