IvanL Posted May 24, 2023 Posted May 24, 2023 Currently there is no easy way to track simulation inputs during the different development stages of a project. Right now the only way to semiautomatize this task is to scrape the data available in the pdf report, which is not very convenient, running into issues quite often due to changes in the assumptions/settings or even with the PVsyst version used. The option to download a csv file with all the assumptions or settings used as inputs together with the main outputs (monthly or yearly generation/losses) for the simulations would significantly enhance the data analysis of the results. If anybody knows a better way to do this I would appreciate any feedback.
dtarin Posted May 24, 2023 Posted May 24, 2023 Exporting the waterfall to excel is one way but misses some inputs.
IvanL Posted May 26, 2023 Author Posted May 26, 2023 Thanks for the suggestion @dtarin but as you say the information there is quite limited and don't really allow for an insightful comparison between the results of different simulation/projects.
