Dear Ayad,
The ohmic resistance of the wiring circuit induces losses ( ELoss =  Rw · I² ) between the power available from the modules and the power at the terminals of the sub-array.
The relevant parameter for the simulation is the Rw value, which is an  equivalent resistance of the wires, as "seen" from the input of the global sub-array  (i.e. the set of MPPT inputs defined in this sub-array). You should define one Rw value for each sub-array in your system.
A PVsyst tool allows you to easily calculate this information in "Detailed Losses" then "Ohmic Losses" then "Detailed Computation"
Regards,
