KTK Posted December 22, 2022 Posted December 22, 2022 Hi Guys, I am currently working on a 8 orientation simulation. All orientations were selected manually and system definition also properly defined. When I check orientation management there are no errors. But despite this I get an error stating " Orientation #3: No Shading field defined!" Can you please let me know the reason behind this error? Regards, KTK
Stéphane Metz Posted December 22, 2022 Posted December 22, 2022 Hi KTK, Indeed, according to your screenshots, it should work. In order to be able to determine what is happening, could you send us your project by email to support@pvsyst.com? Regards, Stéphane M.
Stéphane Metz Posted December 22, 2022 Posted December 22, 2022 This error is caused because orientations 2 and 3 are very close. To solve your problem, you must decrease the detection threshold in the advanced parameters (Parameter #703), for example 0.1° instead of 0.5°:
KTK Posted December 23, 2022 Author Posted December 23, 2022 Thanks a lot. The problem was solved by decreasing the detection threshold.
